Rat Rods Rule Forums
Go Back   Rat Rods Rule Forums > Transmission, Rear End... Q&A!
Transmission, Rear End... Q&A! Tranny, rear end, drivetrain related stuff... shift it... grind it... pop da clutch!
Old 01-18-2010, 01:47 AM
Anarchy's Avatar
Anarchy Anarchy is offline
Default Ford AOD?
Hey guys, been a while since I've been on, but loss of my job kinda put a halt to the rod, but now that I'm working again it's time to get started back up.
I picked up a ford aod tranny from a 85 e150 van I scrapped out and I am wanting to mate it up to my carberated 1981 model 302 which is no big deal
but i know I'm going to need the equivlant to a kick down cable. Does
anyone know of a good company to get a tv cable from. Has anyone had any problems running the aod with a carbed 302? Thanks
No rest for the wicked!
Old 01-18-2010, 09:34 AM
Blue Eyed Devil's Avatar
Devil's Advocate
No problems with an AOD and a carb. The TV cable setup from Lokar is adjustable to just about any setup and works great. Well worth the money spent for headaches saved...
Old 01-18-2010, 12:23 PM
Anarchy's Avatar
Thanks devil, I must have missed it on the lokar site when I was looking at a shifter for it.
Old 01-18-2010, 07:46 PM
i don't know from any personal experience, but i have heard/read that those aod's are a little touchy on the setting of the cable--or tranny will be toast
just thought i'd mention it...
Old 02-06-2010, 02:07 PM
old lady's mad's Avatar
old lady's mad old lady's mad is offline
the preacher is right . im running a 302 carbed and aod . get the lokar kit and follow the directions closly . if not exactly sure about it go to a profesional trans shop and have it adjusted . or you can and mostlikely will burn it up . i love my setup , but they are touchy .
48 ford 2 door sedan frame off , almost in the works
53 f100 frame off not even close to being ready
55 fairlane , driving and changing
Old 02-24-2010, 03:25 PM
coronetrt coronetrt is offline
i am not sue on the ford but on a gm700r4 there is a specific amount of travel when the carb is at wide open throttle. on a gm u will also need a way to apply 12volts to the trans. wiring harness. it can be done with a toggle switch. the cable MUST me pulled
PERFECTLY STRAIGHT. lockar probably has a bracket to fit your carb&your trans.
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
