Old 10-01-2019, 07:19 PM
smallfoot's Avatar
Doing a bang up job!
Old 10-05-2019, 11:59 AM
falconvan's Avatar
falconvan falconvan is offline
Thanks!
Got my steering column and pedals mocked up. The old column was missing several parts and had an add on blinker switch. This one came from an early 60s Dodge truck. Just had to swap the shaft so the steering wheel splines would match. For pedals I modified a set of Fiero pedals and used a Wilwood clutch master and a big bore Mopar brake master. Iíll probably start on wiring next before I start putting the front clip back together. I saved the whole wiring harnesses from the Dakota; Iím just going to modify it and use it.
File Type: jpg 8B0B79AE-94B3-46E4-9A82-AE3B59486872.jpg (125.8 KB, 21 views)
File Type: jpg F94234B5-847D-4042-9EB8-F60FC02517C5.jpg (112.1 KB, 22 views)
Old 10-05-2019, 02:33 PM
Torchie's Avatar
Torchie Torchie is offline
Looks really good.
Old 10-05-2019, 02:39 PM
soltz's Avatar
soltz soltz is offline
The Rat Captain
Thumbs up Coming Along Niceley
Good thinking on re-using the wiring.
Be Safe
and
Be Creative
Old 10-05-2019, 08:14 PM
joedoh joedoh is offline
great work! nice idea to reuse more parts of the buffalo!
Old 10-06-2019, 08:57 AM
falconvan's Avatar
Yeah, Iíve used quite a few universal street rod wiring kits. The wiring itself is good but it seems like the fuse box and connectors (if you get any) are really low quality unless you get one of the high dollar big name brands. Later model factory stuff is pretty good quality just takes a little time to strip it down to the bare essentials of what you need for a basic harness. Plus you have a lot of plugs, sockets, etc that you can reuse.
Old 10-12-2019, 03:12 PM
falconvan's Avatar
Iím not going to paint this but I am going to address a few spots where itís rusted through. I found a core support and another passenger door that will help fix the serious cancer.
Old 10-15-2019, 07:32 PM
falconvan's Avatar
Started getting the front clip back together. I got this grill off the other truck; itís a 1959 but itís in better shape and I like the look. Iíve got a little rust repair on the driverís fender and the passenger door but the rest is going on as is.
File Type: jpg 4F49FD0E-208F-4300-924D-5EBB4FFF8BA4.jpg (107.3 KB, 20 views)
File Type: jpeg A63954D9-8A7C-4012-B521-90110BB0875B.jpeg (119.9 KB, 18 views)
Old 10-15-2019, 08:48 PM
skull's Avatar
skull skull is offline
with the white ''teeth'' stickin' out the front gives it a kinda 'matar look.
Later
my opinion only, valid where prohibited, for official abuse only.
1928 maxwell hybrid build/drag car
http://ratrodsrule.com/forum/showthread.php?t=37455
1948 dodge truck in deceased son's memory.
http://www.ratrodsrule.com/forum/sho...odge+truck+son
1930 2dr mopar.
http://ratrodsrule.com/forum/showthr...ht=30+mopar+dr
Old 10-15-2019, 09:15 PM
beautimous!
