ideas, help & thoughts on front end width...
23crate
Moderator
Staff member
Moderator
Sep 26, 2014
1,387
new zealand
ok need some help with this ..
currently my old coupe (23 Dodge bros) frame uses a 50inch I beam ( king pin centre to centre,
I planning to build a "A" style chassis and use a dropped I beam sitting under the radiator - I saw a suicide front braking under speed once hopping from left to right just looked plain scary so will prob 'z' the frame at each end ..
ok so what is a common width I beam among users here on this site ?
im currently looking at a 48'' and offset wheel centres on the front.. now have to be a little careful - the trunk on this junk is 43" wide, so I cant go too narrow in the front or risk crap steering geometry...
thoughts? haven't quite settled on what rear end yet , hoping to go a bit bigger tyres than the front ..
aiming for a trad style
appreciate any thoughts ideas and or pics !!
thanks 'crate
which axle do you have? some of the t-bucket crowd like the dodge axle because of it's shape. as far as width goes it's up to the owner. some folks like a wider track and some don't some like a narrow front and a wide rear kinda dragster look. a lot stick around the original width.
hmmm ...
am currently looking at a 48" magnum axle with 4" drop ...
Im looking to have a transverse spring front axle, here in new Zealand , if we weld anything to a front axle its no good in the eyes of the national transport body .
I cant go too narrow as at the B pillar the coupe body widens to around 52 inches..
I have these pics gleaned of the 'net .. while its a nice car , its is a little too shiney for me,, I have saved these pictures because this car is similar in Y.O.m to mine and I like the stance / perspective etc
the last brown chevy coupe is similar to where im heading
What's wrong with the original axle?
Just use batwings and bolt them on.
This is a 46" king pin to king pin. Had I used a 48 I'd have another inch of clearance, on each side, for a tighter turn radius.
i'm thinking the same thing, or one the same width with the drop. if you can't weld on the frame i would leave it in the stock location and just get a dropped axle. if you have the room for your tires to clear then you might could narrow it up some. what about building a new frame? can yall do that?
guys, the original front axle got sold off with the rest of original running gear to a restorer, he runs a 20’s Dodge phaeton looks like the original rat rod ( will try for a picture next time I see it ) … I like the simplicity of the A I beam, mount points are wider spaced , lots of good bolt on braking options too. Ps Old Iron - cool look ! planning for similar
over here welds on any front axle need to be crack tested and done by a certified welder, the expense and the hassle its just cheaper to buy a new axle and chuck that in . my original frame is around 22” inside measurement so have a bit to play with
As far as frame build goes, yep , trade qualified body man 20+ years experience cover lots of welding skills and thickness materials can weld mig stick tig oxy/acety I love welding stuff …. I have various T Bucket frame, and 30-31 ford original frame dimensions, and have measured the important dodge frame parts looking forward to that bit the most 
Thanks !!
