Lakota
Rides a rusted horse
A couple of months ago I got the engine and trans together and put in the rat rod, along with the drive shaft. In the process I pulled the muscles in my back. At age 65 it takes that long for back injuries to heal...After a week of going slowly with the exhaust, gas line, and wiring, I fired it up...Cunkity, Clunkity, Clunk. Crap!!! My first thought was bad bearing in the engine. After some screw driver to the ear tests, I found it came from the bell housing area. Brand new flexplate and torque conv. Thinking I didn't get the bolts tight I pulled the trans away from the engine and checked. Bolts to the flexplate were tight on the crankshaft. Slid it back and made sure the bolts to the torque conv were tight. Fired it up...Clunkity, Clunkity, Clunk. Crap!!! I crawled back under with a screw driver to see if the torque conv had too much shaft play, I noticed it.
There was a paper thin gap between the flexplate and the torque conv. I used after market torque conv bolts and they were a smidgen too long and were bottoming out. Knowing the close tolerances between the flexplate and the back of the engine block I decided to slip a washer between the flexplate and the torque conv. No more clunking.
Buyer Beware....sometimes after market parts are not spec'd to OEM parts.
