Marriage of 1955 Dodge C series on 2000 Dakota R/T: Welcome to the wedding!
wheels, mr. 05snopro440, notice how far the offset is? l think you are correct.
if tires and wheels on the front were narrower with different offsets it may correct the problem, but the fenders and all the parts pertaining to the sheet metal will have to be attached to get the true setting of everything to see how it fits together.
went thru with Alice, took apart and reworked things a bunch of times to get so the front fenders didn't rub when l turned.
Later:cool:
According to what I found, those RT wheels are 17×9 with a roughly 6" backspace. So you can go narrower and slightly more positive offset, but you won't gain much. There's a reason the Dakota isn't a common choice, they have a significantly wider track width than the other mid/mini trucks.
Hopefully next week, I can sit the c-series on the frame and start to plan the best way to mount it. A friend of mine (old school paint and body man) is going to supervise me while I cut and fit the floor and firewall onto the c-series.
What's the reasoning for using the Dakota floor and firewall? I've always found this an unnecessary step and amount of work when doing a frame swap. It saves you a little on not mounting other things, but only if they don't need to be moved. That's just me though, I prefer the stock vintage truck floor and firewall personally.
mine
05snopro440 ]What's the reasoning for using the Dakota floor and firewall? I've always found this an unnecessary step and amount of work when doing a frame swap. It saves you a little on not mounting other things, but only if they don't need to be moved. That's just me though, I prefer the stock vintage truck floor and firewall personally.
on mine the people who had it before me butchered the front of the stock frame, so a mid 197O's sub-frame was grafted on which moved the engine back into the cab, so that is why mine has the modified firewall.
Later:cool:
Later:cool:
Yeah sometimes there's need to modify the stock firewall, that's not what I was referring to but thanks for the info. :) I was referring to when people do a frame swap and use the floor and firewall from the donor. It's hard to make it look good.
More disassembly pics 1
pics..
More dissasembly pics 2
pics 2
more disassembly pics 3
pics...
Under hood...
Stance on previous Explorer Frame
Stance on Explorer frame. No drive-train installed in these pics. Rear axle crude measurement is 70” from tire edge to tire edge. The Dakota real axle measures 72” from tire edge to tire edge. The Dakota frame will add 1” to the width of I use a wheel and tire with similar specs.
Vin Decoder Info: I thought it was a 1955
Serial Number.................84652073
Year..............................1954
Make............................Dodge
Model...........................C-1-C8
Engine..........................241 V8
Wheelbase....................116
Rating..........................3/4 Ton
Engineering Code..........VT336
Plant...........................Detroit, Michigan
Build Number................2073
When the previous owner did the frame swap, did he shorten the bed to account for the 4" difference in wheelbase?
I’m not certain if the bed was cut or not. He didn’t say and I didn’t ask. The frame doesn’t look shortened. I’ll try to determine the dimensions of an original bed to see if this one differs.
Sat the bed on between rain showers this evening.
Working between thunderstorms here in NE Georgia. Got the bed sat on just to see what she looks like. Trying to measure some mounting points and bed supports. Gonna try to make some mock ups. Maybe I can get the cab set on the Dakota frame tomorrow after church.
Got cab set on frame for measurements
Shouldn't be too bad!
nice
loooooking gooooood[cl
seems ya don't have to much to trim outta the firewall, is that a rear distributor motor or a coil pack one? mine having a distributor in the back caused lots of mods to make the cab fit correctly.
[P[P[P
Later :cool:
[P[P[P
Later :cool:
It’s a rear distributor! Gonna need to cut and trim a bit to get it in. Or trim in the Dakota floor. Weighing the options!
