meyek91974
I have a daily driver, '97 Explorer, that I use to jump my loose engine which I am trying to get running. I run 2 ga jumper cables from batt pos / neg to positive bolt on loose engine starter bolt and have grounded on starter mounting bolt. I can use neg ground on engine as opposed to previous.
Where I've seen my previous error was that I did not think of the plainly obvious to run a small jump wire from my positive battery post to the positive post on the ignition coil to make the spark.
So, the question is will running the wire to the ignition coil cause or have any danger to my daily driver???? - - feel free to let me know if this is the dumb question of the day. I just cant screw up anything on the daily driver
