Go Back   Rat Rods Rule / Undead Sleds - Hot Rods, Rat Rods, Beaters & Bikes... since 2007! > Builds!
Old 03-14-2019, 03:40 AM
DozerII's Avatar
DozerII DozerII is offline
Thanks Doc
Glen
Old 03-14-2019, 02:45 PM
DozerII's Avatar
Mailman came yesterday with some goodies. I was looking for something different for a pull on the glove box door and found these cool Ram drawer handles.
Wheels are Wheel Viniques Gennies 15x6 and 15x7 I ordered them in gray primmer cuz I want to get them powder coated not sure on color but I'm open to suggestions.
I might have screwed up on my backset measurement after measuring 25 times. Maybe I can roll the fenders out a bit, or I might have to cut the centers out and move them out 1/2"
Glen
Old 03-14-2019, 03:11 PM
If I was you shop teacher you'd get an A+ on your Essex.
Old 03-14-2019, 04:14 PM
joedoh joedoh is offline
wheels are perfect!
I like ruby red, a darker red. silver or ivory would look good too
on your backspace, its probably right, looks like tire bulge is what is sticking out
Old 03-14-2019, 08:27 PM
Perfect as is.
Two words... Moon discs.
Old 03-14-2019, 09:13 PM
Torchie's Avatar
Torchie Torchie is online now
Originally Posted by joedoh View Post
wheels are perfect!
Originally Posted by Dr Crankenstein View Post
Perfect as is.
I agree with the above. But as we like to say around here "It's your car."
If you widen the fender again are you going to be happy with the running board alignment with the fender or are you going to widen those as well? Which in turn leads to ........
I love the moon discs. I always thought they belonged on hot rods and not customs.
Old 03-15-2019, 01:22 AM
dutch dutch is offline
I`m for either ivory or high gloss black 2K paint with dog dish caps
Any color plans for the 440 yet?
Old 03-15-2019, 03:58 AM
DozerII's Avatar
Thanks a bunch Bob
wheels are perfect!
you are correct the bulge is what is sticking out, but dropping the bags 3 inches puts the tire into the out side of the fender.
Perfect as is.
Moon discs not so much, but definitly a hub cap of some kind.
Don't want to widen the fenders again, as you say that change way too many other things, that why I was thinking rolling the vertical part of the fenders out slightly for clearance anyone tried that?
The 440 I'm pretty sure is going to be the old Hemi orange. I'm liking ivory, a red of some kind and the wife is suggesting a burnt orange, and there will be a dog dish style hub cap.
Glen
Old 03-15-2019, 10:06 AM
Torchie's Avatar
Well........
Don't laugh.
When I was a young hooligan the local LEOS would pull you over for every little thing they could find Like no plate light or tires sticking out beyond the fenders.
To "Flare" a set of rear fenders on a neighbors Model A I used a big crescent wrench ( or and adjustable spanner as our Brit friends call it ) to Roll the outer edge of the fender out.
I started at the lower rear edge and about every 1/4 inch or so would put the fender lip in the jaws of the crescent and pull out on the handle causing the lip to flare. I did it in several passes, avoiding the urge to just crank on it .(The impatience of youth).LOL
Then I went after it with a hammer and dolly to smooth things out.It turned out alright for a bunch of teenage punks.
Don't use channel locks as the tendency is to squeeze the handle crushing the bead around the fender lip.
I told you not to laugh....
p.s Bear in mind the you will be stretching the metal and it will change the shape of things somewhat. And this gives you more of a flared look. May not be what you are going for.
Old 03-15-2019, 09:51 PM
Bamamav's Avatar
Bamamav Bamamav is offline
I vote ivory on the wheels. Red and black are overused too much IMHO.
We used to take a wooden baseball bat and put it between the tire and fender lip, the roll the car forward and backward to get a bit of clearance for wider tires. The bat won't gouge it, and you slowly pull upward on it as the car rolls to get the wider gap. Worked great on Mustangs and Camaros.
