Go Back   Undead Sleds / Rat Rods Rule - Hot Rods, Rat Rods, Sleepers, Beaters & Bikes... since 2007! > Tractors
Tractors Yes, we love old tractors too... let's see 'um!
Old 09-04-2020, 10:43 PM
MercuryMac's Avatar
Builder Junky!
Thanks Dutch, I remember your tractor.
I use my A/O outfit lots for the dangdest things. Yes, we need a torch or we can't go on.
Anyhow, I had a town day after two weeks, so there's little progress. The guages are in and the oil line is hooked up. The throttle linkage is hooked up and functional. But when I grabbed the exhaust pipe and muffler I got frustrated, because the bends were a few degrees out everywhere, so it wouldn't fit. I have a Princess Auto pipe bender that I should be shot for buying, but I had learned a few tricks so I should be able to bend some mandrel bends a little bit more, right. --- Wrong. This machine kinks exhaust tubing in three places even in a one or two degree bend, if you don't do some of my tricks. I forgot the tricks and had to learn them over. Too late smart.
Old 09-05-2020, 10:36 PM
MercuryMac's Avatar
Builder Junky!
A little more happened today. The exhaust is all on there and tightened up. All of the steering is mounted and functional.
Old 09-06-2020, 05:08 AM
DozerII's Avatar
DozerII DozerII is offline
Looking good MM, you should be ready for a test drive about first snow.
Glen
Old 09-06-2020, 10:57 PM
MercuryMac's Avatar
Builder Junky!
Thank you Dozer. You may think of me as a flaming optimist, because I'm hoping for a little time before that first snow.
There was quite a bit of taking things back off, today, so I could put something on that was hidden behind something else.
I finally got the battery in and clamped down, both cables installed, and the cable from the safety switch to the starter in place.
Some previous owner cut a chunk out of the fan shroud and that weakened it so it started cracking up. I welded it up and added a new piece so now I'm doing some body work.
Old 09-07-2020, 11:07 PM
MercuryMac's Avatar
Builder Junky!
Here's a picture of the new battery and cables mounted. The battery hold down rod and the ground strap could not be installed with the air cleaner in there. The aircleaner couldn't be removed without taking off the air intake pipe to the carb. The air intake pipe and can't be taken off without taking off the carb, ---- or swearing a lot and prying freshly painted things around.
The second picture is the fan shroud in its second coat of high build primer.
Old 09-15-2020, 11:33 PM
MercuryMac's Avatar
Builder Junky!
Life keeps happening to me, but I finally got back to the Ferguson. Here's the rad and shroud on and clamped in.
