- Joined
- Nov 5, 2015
- Messages
- 3,237
You could run LPG on that compression...
Yah Bud.....sucks. I didn't pay to have it rebuilt, I bought it in supposedly rebuilt condition but was far from done right. Looking back I suppose the right thing woulda been to open it up but buying from a motor shop I thought I was safe and wouldn't have know good from bad unless it was a crack or something very obvious. I'll be looking into the pump gas.....from the corner gas station that isWOW!
Spending the money that was spent the 1st time all over again sucks, but its really good all that crap was caught before it killed the good parts.
I too would be concerned about those 11:1 pistons. Maybe his definition of "pump gas" isn't the same as mine. Racing fuel does come out of a pump, its just not the pump I'd want to have to buy my gas out of.
Not sure if that is what we will settle on but will keep you posted.You could run LPG on that compression...
Yes.... Hot Heads AluminumI just remembered something, isn't the heads on that engine aluminum? If so it most likely can handle the 11:1
The cast iron headed engines cannot run 91 pump gas at 11:1
I see.... that stuff is all greek to me!E85 requires a new carb metered for the alcohol
My 392 is 10:1 with iron heads. At 30 degrees of timing I run 87 octane at 36 degrees I run 91
The total timing on a Mopar is deemed to provide the best performance at 36 degrees total advance. If the motor pings at that 36 degrees of total advance, you either add higher octane fuel, or you reduce the total timing until the pinging quits. Reducing the timing generally reduces the maximum performance.I see.... that stuff is all greek to me!
I`m sure Tripper will step in once you eat up more space than pics do...
Yea, I'll try to keep the stories short stories.
I bet you can't! LOL!Yea, I'll try to keep the stories short stories.
Is that a challenge???? LOL!I bet you can't! LOL!
Keep typing Gene, I need the edumacation!
