Masking tape
oddpowers
Jul 11, 2013
140
ANDERSON, IN
Ok, I'm looking to add some scallops to my 58 Ford. I bought some .25 wide masking tape, but I'm having trouble making it stick. And it doesn't do corners very well.
What does everyone else use? And where do you get it?
If you want 1\4" stripes but have touble in the curves use 1/8" in the curves,side by side+then be sure to put a piece of tape in the middle to cover the gap.
THanks all! I stopped buy the local paint supply place and got some NORTON. I'll try it for practice, then use 3M when I'm ready to do the real deal.
The green "painters" tape is for trim in homes. It is a low stick tape designed to not pull of wood work finish. Use the blue plastic 3M fine line.
