My version of a 46 chevy pu
Not all front ends are created equal.You'll have a hard time getting the look you want with the nova sus,like the S10 they dont look as well going fenderless.You can move the cab back but the frame gets wider as you go back causing some mounting problems.Some guys have used extended cab
S10 frames and slide the cab back but you still have the front suspension that is not very appealing.My 53 build is on a s10 frame but im not going fenderless.You might google rods on s10 frame to get ideas how your will look.
And even with the cab slid back, you can only shorten the front rails so much due to the steering box, etc. There are very few stock IFS suspensions that look good fenderless.
Just tuned in and followed through
Sweet build! Did you use plastic air lines? What type of connectors did you use, I have some tees that keep popping apart...:eek:
