Old 11-17-2019, 11:54 PM
Burgerman's Avatar
Burgerman Burgerman is offline
Like the stand, like the COE.
Old 11-18-2019, 04:41 AM
DozerII's Avatar
DozerII DozerII is offline
Test stand looks really good JB, you may have to start attending meetings as well.
Glen
My 29 Essex Build http://ratrodsrule.com/forum/showthread.php?t=34026
Don't give up, it's far too much fun once you can drive it.
Old 11-18-2019, 06:44 AM
BillM's Avatar
BillM BillM is offline
What they all said - stand looks really sturdy, and I sure hope that COE works out for you. I'd love to build one of them.
Old 11-18-2019, 07:06 PM
endicott_jb's Avatar
endicott_jb endicott_jb is offline
I donít know what youíre talking about. I swear I donít have a problem and can stop at any time if I want to.
Yeah, engine stand is a beast. Most is built out of 1/4Ē tube, plate, and channel. Most of it was steel I had lying around left over from other projects so I donít have much into it but Iíll make a pretty penny from it.
If life throws you lemons, switch to boomerangs.
1933 Chevy thread
http://ratrodsrule.com/forum/showthread.php?t=28825
1931 Chevy thread
http://ratrodsrule.com/forum/showthread.php?t=33579
1928 essex coupe
http://ratrodsrule.com/forum/showthread.php?t=36305
1918 dodge roadster
http://ratrodsrule.com/forum/showthr...659#post528659
Old 11-20-2019, 08:37 PM
All the fabrication is done on the test stand. Waiting on the tach to come in to finish the wiring then itíll go off to its owner. Had some spare time left so decided to build the alternator bracket for the Y block so I could use a common GM alternator. Still need to cut the adjustment slot but I figure I can do that tomorrow.
1933 Chevy thread
1931 Chevy thread
1928 essex coupe
1918 dodge roadster
Old 11-20-2019, 10:56 PM
Torchie's Avatar
Torchie Torchie is offline
Old 11-27-2019, 07:53 PM
So, been working on the alternator bracket the last few days. Ended up cutting another one out and using the previous as a template(it will be stashed away as a ďprototypeĒ.) After putting it all together I thought it needed something else so I decided to accentuate it with a bit of copper. Once I had it completely covered, I decided it needed something else to really make it pop. So I cut in 1Ē from the edges and drilled holes for some sickle rivets. Iím really diggin the way it turned out now. I think itíll really tie the interior and the trunk into the exterior. Now, because everything else now looks so pretty, I had to paint the crank pulley. So itís currently drying. Might even have to paint the water pump pulley Iím gonna wait to see how it looks against the crank pulley first though.
1933 Chevy thread
1931 Chevy thread
1928 essex coupe
1918 dodge roadster
Old 11-27-2019, 09:08 PM
Bamamav's Avatar
Bamamav Bamamav is offline
It's like a snowball rolling down hill.......pretty up one part, you see another that needs something, then another, then another......
That's one reason it takes me so long to get anything done!
2019 Undead Sleds Calendars available here--
https://www.zazzle.com/2019_undead_s...18503957825055
Old 11-27-2019, 10:28 PM
Liking that bracket JB.
"I think therefore i am" Rene Descartes" 1596-1650
"I think therefore i am probably a holographic simulation" C.Brown 1947-
Old 11-28-2019, 12:21 PM
