![]() Thanks!
39 Ford PU Build. http://ratrodsrule.com/forum/showthread.php?t=36459 The thing about a '39 Ford pick-up is that that ugly grille kinda' grows on ya' after a while. Not taking anything too seriously. ![]() |
I always used Econoline or G10 chevy van front axles.Traditional axles are almost impossible to find here on coast.So, we use what we have.
We have used 2 methods to deal with the steering arm issue. I have heated and bent the steering arm to clear.Have also cut it off and bolted one I made out of 3/8 plate to top spindle bolts. If you make one to bolt on be sure to bend ears down to fit holes. Do not weld them on. I used cardboard to make templete and cut and bent it with standard torch.A little grinding and it looks great. My current woodie project will have a 65 Econoline axle and will need to cross steer,so I will have to go back to drawing board to find what is best that way. Hope this helps. And Remember "Safety First" ![]() |
A bit belated thank you, Rex. Much appreciated. It looks like cutting it off and making a new one is the workable option. I have seen some done this way since I started looking a bit.
We make steering arms for the Econoline spindles.
http://shop.eztbucket.com/Lower-Steering-Arm-3007.htm |
![]() Quote:
Your product would be the easy way for sure, and the price is right. Unfortunately, I am looking for options for the upper arm. The one the drag link connects to. Also drum brakes are what I have at the moment. Can you cover that?
Bookmarks |
Thread Tools | |
Display Modes | |
