Chrome or billet aluminum pulleys are famous for letting the belts slip. I guess it is because the surfaces are so smooth they have no tooth to them.
Do you think the brake fluid will shorten the life of the belts ? Reason I ask is that I used some belt dressing on the serpentine belt on my daily and it make it gummy and I had to replace it. Don |
![]() Quote:
sometimes sanding the pulls helps or the ribbed belts sometimes are better for no noise than the solid ones.....JMHO>...
My 96 GMC Rat Buildbuildthread |
Use belts made in the USA
![]() Quote:
![]() When I was in high school a friend of mine had a '69 Super Bee and even though it was only about 5 years old it was pretty ragged out from being flogged on a regular basis. He worked at a convenience store down the street from my house and usually got off work at midnight. One night I walked down and met him and we were going to go flog the Super Bee around town. It was low on oil so he topped it off and I pushed him across the parking lot to start it......weak battery........ when it fired it up the fan belt started squealing like crazy. Not being the smartest guy in the world, he grabbed a quart of oil from the rear floor board and dumped some on the belts..........they shut right up ![]() ![]()
My '53 Willys Build thread My Current Off Topic Build Paradise Road First House on The Right "Sometimes a right proper choking is "just what the Doctor ordered". ![]() "......... Ratrodsrule.com. A hot rod refuge from the vulgar, the crass and the profane." -- bob w "I need to get my front bumper calibrated. It makes more of a BANG!!! type noise." -- Flipper |
Coarse sandpaper on the "traction" sides of a running V-belt cuts off the hard glaze. (Watch your fingers.
![]() Quote:
- The distinction between psychological illness and creative thinking is wafer thin - 1937 Chevy Coupe 1938 Chevy Sedan |
I used to hold a flat file on a running belt to break the glaze. Then rub some brake fluid on. I don't remember how well it worked. That was 30 some odd years ago.
Hot things look just like Cold things ![]() Offroadrolls build: http://ratrodsrule.com/forum/showthread.php?t=23696 42 Chevy PU build: http://ratrodsrule.com/forum/showthr...ht=42+chevy+pu |
We always used liquid dish soap or ran a bar of soap against the belt. It's a temporary fix tho.
I've used this method. Seems to work for quite awhile.
dmw...Livin' on Route 66 ![]() "No matter how smart you are you can never convince someone stupid that they are stupid." 34 Ford Coupe 51 Ford F1 50 Stude Champ Intro |
I found that basically all cheap belts squeal no matter how tight. Autozone, Dayco, and the like are terrible.
Get good quality Gates belts if possible. And don't over tighten belts, it will eventually ruin your accessories bearings. And I have heard it will ruin your #1 main bearing and crankshaft in extreme cases. |
Bookmarks |
Thread Tools | |
Display Modes | |
