Willowbilly3
A *real* tin magnet
Since there is already a thread discussing this it got me to thinking about triangluated 4 bars...again. I am not posting this to hack on other people's design, just to point out what my conclusions are and how I arrived at them.
Personally, I think the widest point of the triangle should be on the rear axle, not the frame mounts. If you think about the twisting forces applied if one tire had traction, and one didn't, the design with the axle mounts out toward the wheels is going to receive less stress to several times the magnitude than the design with the mounts close in to the punkin. To make the point, have someone hold a 4' long stick with both hands together in the middle and you grab the ends and try to wrench it free. Now hang on right next to the other guys hands and try it again.
Not only that, the arc of travel is a lot greater with the outward mount so suspension deflection (of one wheel) will be more on the axis of the bushing instead of twisting the bushing. Make sense?
