36 Ford Bobber Build
I set the cab on the frame to start planning cab and axle placements.
Thanks guys!
I set the grill roughly in place with the hood for a spacer to get a feel for length. The grill obviously will have to sit lower and may need to be sectioned a little to keep it from dragging on the ground but that's a future worry. The frame rails need to be pushed out a bit in front to get the spacing right anyway and they are what's keeping the grill from sitting down lower at the moment. I'm not planning to run the hood but I will set it up so that it can be put on if I want to. You can't see it well in this pic but the hood is louvered and the patina matches the cab really well which is cool since it came from a different truck! The inside of the hood is painted county vehicle orange:eek: I'll probably trim the fronts of the frame rails too since they stick out quite a ways.
Looo-kin' gooooood! [cl
I'd be really tempted to slide the bottom of the grille all the way out to the end of the frame rails.
