29 rpu build
dogpatch1
Oct 5, 2008
856
toledo ohio
Havent been on in a while, Moved then started my own business and stuff....
decided these parts have sat around long enuf...
unloading with my helper, and a mock up
dp1
dash
chevy pickup dash cut, narrowed and welded back together, will be cutting out two large hole and going with one harley bezel and gauge
doors today
working on the doors rust thru at both bottoms so cutting and welding....sorry for the crappy cell phone pics....
The rear panel came about 7 inches shorter then the sides, so i made a top panel with the same bead i rolled in each quarter panel behind the doors.
can you tell what engine im going to throw in it?;)
cab n frame
so i had a late night at the shop, primed the cab and doors, then started throwing the front and rear axles under her, she's a roller almost....last pic is the engine ill use, coming out of the gto, getting replaced with a turbo Ls 6.0
hey Tripper, how have you been havent been on in a while. george
making my bed
spent most of Saturday building a bed. It is a 1 inch square tube frame, I made the bed front, side, side fillers, and tailgate all on my brake and bead roller.
pics
some progress pic of bed
more of bed
test fitting exhaust pipes and fenders and moved outside for a better pic.
