Old 04-01-2013, 09:35 AM
Flipper_1938's Avatar
Flipper_1938 Flipper_1938 is offline
He recycles the right way
Another pic of that 1936 Jag...
There are two things in life where penetration is really important .....and one of them is welding.
My 48 chevy flatbed http://ratrodsrule.com/forum/showthread.php?t=604
The Roofus Special http://ratrodsrule.com/forum/showthr...ghlight=roofus
Old 04-01-2013, 12:39 PM
klink's Avatar
klink klink is offline
Are you trying to convince us that fenders would be the right direction, or are you just torturing yourself...
Klink...
My 1930 Chevy Build.
http://www.ratrodsrule.com/forum/showthread.php?t=21244
My 1953 Chevy Build.
https://ratrodsrule.com/forum/showthread.php?t=39254
Old 04-01-2013, 01:09 PM
Just posting the other pic that I found.
Roofus will be fenderless.
Old 04-01-2013, 02:31 PM
Shea Laking's Avatar
Shea Laking Shea Laking is offline
Originally Posted by Flipper_1938 View Post
Did i ever reveal that the frame is built out of porch posts amd a cooling rack for ceiling fan parts?
Must be easy to get a title for "homebuilts" in Kentucky? Here in Ontario, we'd have to jump through hoops of fire to pull it off, I believe.
Looking forward to touchdown on all fours... As I'm sure you are as well.
Regards,
Shea
"Just cause you could doesn't mean you should"-Davidhud29
Father,School Bus Mechanic, Home Handyman, Car Lover, Husband-All to varying degrees of mediocrity
Old 04-01-2013, 02:59 PM
Regards,
Shea
It's not a homebuilt. It is a 1960 Jaguar MK2 that has been modified.
Old 04-01-2013, 06:41 PM
klink's Avatar
A two piece windshield would look good on your '60 mk2...
Klink...
Old 04-07-2013, 09:46 PM
I worked on figuring out what it will take to get the upper a-arms attached to the frame.
I cut these from a piece of 2x4
so that I could do this
The idea is to mount the mercedes shafts on plates so that the arms can be bolted to the frame. The problem is that the frame is not square with the world...the rails are pinched.
The arms need to be mounted at an angle.
simple enough...in theory
now to make it pretty
I had to make a mirror image one too...
Next step will be to prep the front rails for the arms.
Old 04-08-2013, 07:26 AM
falconvan falconvan is offline
Looking good; you'll be sitting on 4 wheels before you know it.
Old 04-09-2013, 07:42 AM
I'm probably going to slot the mounting holes so that I have some adjustment for caster.
