Go Back   Undead Sleds / Rat Rods Rule - Hot Rods, Rat Rods, Sleepers, Beaters & Bikes... since 2007! > Fuel systems Q&A
Fuel systems Q&A Carbs, injection, tanks, lines, pumps, everything fuel system related!
Old 12-31-2019, 04:24 PM
23crate's Avatar
23crate 23crate is offline
Default Electrickery fuel pumps...
hey all..
my studes electric fuel pump , has shown signs of imminent failure.
went shopping for a replacement . picked up a 4-6psi 96gph , which just stopped working around 3 mins after starting the car.. needless to say i was a bit unhappy - id spent 1.5hrs tidying up someones mess as the same time..
im wondering what you guys use in the way of electric fuel pumps? recommend them or prefer mechanical?
keen to hear all thoughts / suggestions ..
thanks 'crate
ps the original 259 mech pump was in place when i got the car , but i suspect had blown a diaphram due to oil blasting out of the breather hole.
ive replaced mech pump with a SBC blanking plate - nice fit too..
duct tape can't fix stupid, but it can muffle the sound.
the greatest victory is to live
Old 12-31-2019, 05:20 PM
Bamamav's Avatar
Bamamav Bamamav is offline
Crate, I like the little Facett pumps. They come in several different pressures and hose sizes. Mr Gasket and Purolater both also have a version of them, too.
Old 12-31-2019, 07:58 PM
Nailhead's Avatar
Nailhead Nailhead is offline
I use mechanical pumps on all my Hot Rods. Haven’t had a failure in many years
‘38 Chevy Coupe 409 w/switch pitch TH400
‘50 Chevy Sedan Delivery 401 Nailhead TH400 Gear Venders OD
‘65 Buick Skylark GS Clone 401 Nailhead TH400
Old 01-01-2020, 01:42 AM
smallfoot's Avatar
Mechanical on mine too but have run electrics. both usually work well for long periods. Have you proven everything else good? The first pump was failing and the replacement went out. Could there be a blocked fuel line or something electrical that's killing pumps?
Old 01-01-2020, 05:13 AM
23crate's Avatar
slowly been working all the bugs with car ,, the mech pump was a repro part . ive since found out there was a batch of faulty ones that had an oil seal put in backwards as a result oil leaks out the diaphram breather hole. strip and assemble has proven i cant solve it.
the electric replacement just isnt sucking the fuel up , and should be close to the gas tank not the engine room where it is .. ( this one has fueled the car inb the 6motnths ive had it)
wiring is good ..
sigh
Old 01-01-2020, 09:13 AM
Holley blue, no more than 24" from the tank, with regulator and return line to the tank. Set to 6 to 7 psi.
If you don't run a return line, the pump will dead head and fail.
Old 01-01-2020, 11:03 AM
I run elec pumps for 2 reasons. They can be used as a theft deterrent & I like to route my gas lines from the firewall instead of the front of the engine! Never had one fail!
Old 01-01-2020, 04:20 PM
Generally speaking, electric pumps push better than they pull... ideally, the pump should be close to the tank and "wet" by gravity...
Old 01-02-2020, 02:39 AM
23crate's Avatar
Thumbs up
thanks all
Tripper in interested to know how these 'lectric pumps foil would be robbers,,
Dr C thanks ill keep that in mind .. these are new to me -- usually ive run mech pumps...
ive ordered a Carter mechanical pump from rockauto today ,, will go argue with electric pump retailer tomorrow... dont think ill use it .. may be handy for the dodge project.. space issues and all that
Old 01-02-2020, 08:32 AM
noahvale's Avatar
noahvale noahvale is offline
The Holley Red version does not need a return line. I have one in my Rambler.
That motor sounds like a brick in a dryer
https://60ramblerwagon.blogspot.com
