Go Back   Undead Sleds / Rat Rods Rule - Hot Rods, Rat Rods, Sleepers, Beaters & Bikes... since 2007! > Tech Tips!
Old 01-18-2011, 01:23 PM
Tim...Ok's Avatar
Tim...Ok Tim...Ok is offline
if you don't have copper handy,a chunk of aluminum works very well too..I really like the long vise grip idea..thanks!!
Old 01-18-2011, 01:42 PM
Rust in peace Rust in peace is offline
I like to use a piece of filler metal for places that are hard to access from behind. It requires less heat than trying to weld the entire hole shut.
I use a nail with the head just smaller than the hole. Weld around the edge then cut off the shank.
If the hole is too big for a nail head I tack a nail head inside a washer hole. Then weld the washer in the hole and cut off the shank.
I like to use the copper backer for floor pans.
Old 01-19-2011, 12:41 AM
Haawt Pocket's Avatar
Haawt Pocket Haawt Pocket is offline
Cool idea with the vise-grips and washers! Thanks
Anyone who doesn't like a rat must own cheese.
Old 01-19-2011, 08:21 PM
DARK RAGING's Avatar
DARK RAGING DARK RAGING is offline
Great idea will use this one.
THANKS
Old 01-20-2011, 03:48 AM
Jimmy Wallbanger's Avatar
Jimmy Wallbanger Jimmy Wallbanger is offline
I used the nail and washer idea on welding up tubing and pipe ends! bonus is you can hold the shank to tack it in!
Old 01-23-2011, 04:11 PM
tkkruzer tkkruzer is offline
Default welding trim holes
i use roofing nails on mine. the head is much larger than most trim holes so you just poke it thru from the back , hold it with plyers and tack it in place then cut off the shank. if the hold is bigger then just use 2 nails. less heat =less warpage
Old 01-23-2011, 07:16 PM
olcarguy's Avatar
olcarguy olcarguy is offline
Only problem with roofing nails is they are galvanized, That's real mean sh++ on your lungs when heated with the heat of welding.
Measure with a Micrometer. Mark it with Chalk. Cut it with a torch......
I am the fastest of the slow learners....
I am Canadian!
46 Ford p/u build[http://ratrodsrule.com/forum/showthread.php?t=15630]
http://tinyurl.com/3bclsh
