Go Back   Undead Sleds / Rat Rods Rule - Hot Rods, Rat Rods, Sleepers, Beaters & Bikes... since 2007! > Questions/Suggestions
Questions/Suggestions Questions or suggestions about the forum... don't be shy!
Old 03-09-2011, 06:28 PM
izzy's Avatar
izzy izzy is offline
Default re re rewiring my rat friday
i hope i get it right this time, bought new wire and have a good friend coming over to help, maybe the third time is the charm. glad i found this rag, i read a bunch of old threads and found great advice in most of them.
Old 03-09-2011, 07:27 PM
So what has been the problem before?
Old 03-14-2011, 10:38 PM
sneakysnake's Avatar
sneakysnake sneakysnake is offline
"There’s nothing new in originality"
You can always though us some pics we'll be glad to help.
'46 Build Link
'53 Build Link
"Its a catastrophic success"
Old 05-05-2011, 09:11 PM
Carlos Murphy Carlos Murphy is offline
Default Rewiring...
Yeah, not looking forward to rewiring my 50 Stude pickup
Previous owner did all the electrics 17 years ago when he built it, oooold school with junction blocks all over the place.
Wana yank it all out and replace it with something from Painless or EZ Wiring. I would rather drive it than work on it unless its to install a HEMI but THAT ain't guna happen.
Good luck.
Old 05-05-2011, 11:33 PM
skull's Avatar
skull skull is offline
''SARCASM: just one of his many talents.''
Lightbulb had both
l have used the E-Z wiring harness and the painless.
l like the painless one l got 'cause it has the switches and a keyed ingintion included and most of the ends already on or, you can order without switches or ends.
the E-Z harnes company has everything, switches and ends you can order, these parts extra $$ , and not attached, or you can provide youre own wire ends and switches from the local parts store.
both are 'bout the same to install.
the price has went up since l bought mine a couple years ago, so l have no idea on prices.
hope this helps
Later
my opinion only, valid where prohibited, for official abuse only.
1928 maxwell hybrid build/drag car
http://ratrodsrule.com/forum/showthread.php?t=37455
1948 dodge truck in deceased son's memory.
http://www.ratrodsrule.com/forum/sho...odge+truck+son
1930 2dr mopar.
http://ratrodsrule.com/forum/showthr...ht=30+mopar+dr
Old 05-06-2011, 05:51 AM
Default Wiring
Thanx for the info.
Old 05-06-2011, 07:25 AM
Toad's Avatar
Toad Toad is offline
I prefer Rebel Wire kits. Heavier gauge wire with bigger lettering on the wires. They also answer their phones and freely give advice and help. My .02!
Toad
Why did the toad cross the road?
Old 05-07-2011, 04:29 PM
dyce51 dyce51 is offline
This is one thing I actually love to do!! I have wired (from scratch) 3 different hot rods, 2 motorcycles and 2 4x4 trucks! Wireing can be a bit tricky but as long as you use the right gauge wires and make good grounds you should be fine.
"If the ground is a-shaken, and the flames are green, they is-a runnin' that hydrazine!"
Old 06-17-2011, 09:27 AM
RatTrap's Avatar
RatTrap RatTrap is offline
Question So is there a chart or something
Does anyone have a link or a chart that shows the correct gauges
to use?
I bought my rat and quickly found out that only a few of the switches do what they are supposed to. Nothing is labled.
The switch I was told was the fuel pump does who knows what,
I have a cam operated fuel pump. Also found out I was running with
no tail lights, that was another mystery switch that I have since located.
One switch I was told to turn on wasn't even wired to anything, I guess it just looked good hanging there.
Can you tell I am new to this game?
Please teach this old dog some new tricks.
Old 06-17-2011, 04:40 PM
Rule of thumb,and consider length of wire run,(longer the run bigger the wire)
park,tail and marker lights and (low loads)=14-16 ga. 10 amps
small motors, wipers, headlights, (med load)=12-14ga.15-20 amps
large motors,cooling fans,alt(heavy load)=10 ga.30 amps
If in doubt use the next bigger wire, the only draw back to to using to big a wire is the cost and workablity of it.
'46 Build Link
'53 Build Link
