Go Back   Undead Sleds / Rat Rods Rule - Hot Rods, Rat Rods, Sleepers, Beaters & Bikes... since 2007! > Questions/Suggestions
Questions/Suggestions Questions or suggestions about the forum... don't be shy!
Old 06-23-2007, 12:43 AM
shoobear shoobear is offline
Default 31 ford bolt pattern fit anything newer?
Hey anybody know if my 31 ford bolt pattern is the same as a newer vehicle?
Looking to put a set on to roll the car around, those rubber on my wire wheels are totally flat/done!!!!
cheers
"senoritas caliente y cervesas fria"
Old 06-23-2007, 01:03 AM
shoobear, your bolt pattern is 5 on 5.5. Check the attached chart below. There are numerous later applications that would apply. I would suggest going to a junkyard and getting the spare tires from vehicles with the same bolt pattern. They usually almost give them away.
http://www.stagewest4x4.com/store2/s...lt-pattern.htm
Old 06-29-2007, 07:17 AM
R Pope R Pope is offline
Ford half-ton wheels fit, so do Dodge half-ton, '85-up.
Old 02-06-2008, 12:45 PM
freakdude's Avatar
freakdude freakdude is offline
Early Jeeps like the cj5 are the same....
Old 02-06-2008, 01:19 PM
Willowbilly3 Willowbilly3 is offline
A *real* tin magnet
and international scout
