Builds! Post your project here... show us what you're up to! Please Note: This section is for "Builds" ONLY! |
Thread Tools | Display Modes |
#211
He who dies with the most toys wins
#212
Hahaha, yeah it takes up lots of room !!!
Trailer queens suck! Build it, drive it and be safe! Minterfab.com |
#213
Chop chop' 2" off the top!
Pretty sure i read somewhere by lip Jack and straps were the only way to align your model A Body Lines
#214
![]() Quote:
#215
Porta-power ain't got nuttin on you!
#216
Got rat rod tonight, had to build some fancy pipe 90s for the upper radiator hose. I still need to tap the steam ports into the 90. Then it can be filled all the way up with coolant. Also got the transmission dip stick mounted and the engine dip stick installed. Finished mounting the dimmer switch and the head light switch. Getting closer
#217
Steam port line finished, steering spacer being made, dash wired. Still working away!
#218
Steering is 100% done now. Front and rear axles are tight., key switch and dash are installed and wired. Battery is tied down. Getting closer. Going to the tuner on friday!
#219
#220
Yeah, not much room at all!!
Thanks!
Bookmarks |
Thread Tools | |
Display Modes | |
