TubularFab
Active member
I have had no luck finding a place willing to put this block in a wheelabrator. Nor have I been able to find a local shop to vat it. So I soaked it down with naval jelly and got most of the rust off inside and out. But - I wasn’t happy with it - it did not not want to clean off afterward! So, on to plan B. I had a heavy plastic barrel that it seemed like the block would fit in on end. I mounted an electric heating element from a hot tub in the bottom then made a stainless platform to sit just above it. The block just fit... Filled it with water and 5 gallon bucket of Zep purple cleaner ($36) from Home Depot. It’s a strong base - sodium hydroxide. The heater easily gets it to 150 degrees and it wasn’t long before all the naval jelly residue was gone. This is cleaning the air box carbon that the vatting I had done years ago didn’t get!
