Go Back   Rat Rods Rule / Undead Sleds - Hot Rods, Rat Rods, Beaters & Bikes... since 2007! > Electrical... Talk & Q&A!
Electrical... Talk & Q&A! Electrical Q&A.. The shocking truth, tips, tricks & more!
Old 04-16-2018, 08:39 AM
pacrat1 pacrat1 is offline
Default Ford distributor question
I'm putting a 1982 - 84 5.0, or Windsor, in a 1964 Comet. The distributor on the 5.0, has about a dozen wires coming out it. This is way more wires than I need. Do I pick 2 wires, and ignore the rest ?, or do I need another distributor.
I know this is probably a very basic question, but eanie meanie miney moe gets expensive.
I'm getting ready to pull engine. Didn't know I needed front sump, and have to drill hole in timing cover for oil dipstick.
"Heat It and Beat It, and Paint It to Match ! "
Ode to a sledgehammer mechanic
Old 04-16-2018, 06:03 PM
If it's a factory ignition, it's either a Duraspark system (requires external control module) or an EEC system (computer controlled). Neither can operate with one or two wires straight off the distributor.
Show us what you have, pacrat. We'll figure it out...
Old 04-16-2018, 09:29 PM
Bamamav's Avatar
Bamamav Bamamav is offline
You have a computer controlled distributor, throw it away.Either get a 85 Mustang manual trans distributor that hooks to a Duraspark box with 2 or 3 wires, or one of the Hei style dist s off of eBay. Or lastly, you could use a early points distributor but you will need to change the cast gear to a steel one. That is the route I took.
Get the front sump oil pickup, too. Some timing covers were drilled and have a plug in them, but drilling one isn't hard.
You can do the job with mostly OEM parts. Distributor gear might have to be aftermarket since the early shaft is smaller. Other stuff is local junkyard parts.
Old 04-17-2018, 07:56 AM
Blue Eyed Devil's Avatar
Devil's Advocate
Time for a Pertronix HEI unit. You won't be disappointed.
Old 04-18-2018, 06:40 PM
Default Pictures of distributor 5.0
I hope these pictures work. I have shown the distributor, and some of the unneeded? pollution parts. I'm not familiar with stock electronic distributor.
I'm trying to use this motor in a 1964 Comet.
Old 04-18-2018, 07:45 PM
kenny c kenny c is offline
I have a 2001 302 out of an explorer. I used a distributor from a 67 302. I had to change the gear to one that will run on the roller cam. can't remember which one now.
Tetanus Tornado 49 F6
Old 04-18-2018, 09:45 PM
Bamamav's Avatar
Steel gear for a roller cam, cast iron for flat tappets. Steel gear is real smooth, a cast gear will have little pits in it.
Old 04-19-2018, 08:16 PM
Thanks Bam
Old 04-19-2018, 10:49 PM
Thanks for all the information guys. I appreciate your help, and patience.
Old Yesterday, 07:53 AM
I'm with BED on this one.
