59ponchorat
just bought 64 caddy and need the tank boiled out and coated..anybody got sources near greenville south carolina..im ready to drive this ship..thanks
I own a radiator shop out in OR, and we clean out tanks all the time. I would stay away from coating your tank. it makes it impossible to work on it after it's been sealed. You could clean it yourself, you need to get a couple cups of caustic soda, fill the tank with water and let er sit for 3-4 days. should be clean after that depending on how bad it is. if not just do it again. put gas in it after that and don't bother coating it hope this helps. if you do coat it get a really good one. iv'e seen the coating not stick after a while and clog up lines and filter like crazy.
