Rust Removal with Foil....
RR again... this time with me
I figured I would put this to the test....
I think it came out well!
I have to wonder about the coke. [S
I watched the video and there is no dwell time for the coke to actually do anything. Maybe it's just a lubricant and the real work is done by the foil???
I wonder if oil would work just as good? Maybe even dirty oil as it has grit in it.
I know that you can use water and it works, the coke can remove rust without foil, it does take a bit longer though
I think it was on that new car show on TV, "Garage Squad" where they did the tin foil and coke trick on an old bumper. I will have to try it.
