Go Back   Rat Rods Rule / Undead Sleds - Hot Rods, Rat Rods, Beaters & Bikes... since 2007! > Builds!
Old 02-13-2018, 06:59 AM
DozerII's Avatar
DozerII DozerII is offline
Interior looks great, and so does the art work
Glen
Old 02-14-2018, 12:54 AM
Burgerman's Avatar
Burgerman Burgerman is offline
Default Very nice work
A pleasure to see. Thanks for sharing
Old 06-25-2018, 11:43 AM
bkvail bkvail is offline
sorry it's been so long since I have updated - we are still plugging away and getting really close to it being really road-worthy. We did take it around the block again yesterday and did have some minor tire rubbing when the springs went under compression on a corner. Normal driving on flat road it didn't rub, but pulling through the grass, it did. We spent most of the spring raising the cab and all the tin up an inch for tire clearance. It was almost enough I guess. We also switched from 2'' wheel spacers to 1.5''. It was almost enough I guess. I think it is close enough we can live with it though, it's never going to have a showroom paint job in our lifetime. It WILL get paint though. We keep going back and forth. Something original for this truck would be an aqua/turquoise color - but it looks so good in black haha. Black goes good with everything. Then, we think - black cherry would be nice. Or a black/bronze color would be awesome too. Too many colors we like!
Anyhow - we worked on the rotten fender replacing a large section of rot and severe damage. We cut out a chunk from a fender with severe damage in other places and grafted it into the original fender.
20180605_170054 by Karin Vail, on Flickr
Brian is getting better at the sheet metal welding - this turned out the best of any sheet metal welds he has done. It is almost metal-finishable! It will need VERY little body filler. He did tack by tack and cooled each and every tack along the way and got almost no shrinkage. He also did it by spreading it along several days. I forgot to get a pic of the final welds, oops.
We got the exhaust ALMOST done too - just need to decide on stack mounts. Brian is trying to think hard how he can mount the stacks without a cab mount, but without a big ugly mount high off the frame. Any suggestions?
20180624_134453-1 by Karin Vail, on Flickr
Old 06-25-2018, 01:27 PM
lowbudget50's Avatar
Looks very good!! The truck has a really nice stance!!
Minterfab.com
Old 06-25-2018, 01:56 PM
I agree with lowb
Brian is doing a great job on his welds!!!!!!!!!!!!!!!!!!
Old 06-25-2018, 04:03 PM
smallfoot's Avatar
I like the stance too...nice job!
Old 06-25-2018, 05:41 PM
Skip's Avatar
Skip Skip is offline
"We got the exhaust ALMOST done too - just need to decide on stack mounts. Brian is trying to think hard how he can mount the stacks without a cab mount, but without a big ugly mount high off the frame. Any suggestions?"
This a challenge that Daimler hasn't sorted out either. At least not before I retired. Maybe some well hidden behind the pipes little ugly mounts just high enough off the frame? Something that looks like a headache rack perhaps? If you add rubber vibration dampers of some sort to the mounts, it will cut down on a few issues. Since you are not likely to be taking it long-haul, is should hold up fine with smaller supports.
39 Ford PU Build. http://ratrodsrule.com/forum/showthread.php?t=36459
Old 06-26-2018, 12:47 AM
dutch dutch is offline
I LOVE it!!
Old 06-26-2018, 04:12 AM
DozerII's Avatar
That's coming together really nicely.
Glen
Old 06-26-2018, 06:11 AM
forbigpicture's Avatar
forbigpicture forbigpicture is offline
Please stand by.......
Lot a nice work there..... I dig it....
