Go Back   Rat Rods Rule / Undead Sleds - Hot Rods, Rat Rods, Beaters & Bikes... since 2007! > Body... Talk & Q&A
Body... Talk & Q&A Top Chop, Channel & General Body Q&A
Old 05-11-2017, 08:02 PM
serrata serrata is offline
Default 33 chevy windshield mounting...
My 33 chevy looks like the windshield mounted from the inside originally. Should I mount it from the inside or make a 1/2" inside-radius lip and mount it from the outside?
Is it a safety issue in modern times to have the windshield mount from the inside? Things were much different back then. 60hp didn't push very hard.
Old 05-11-2017, 09:03 PM
Do you have the inside garnish molding? (It squeezes the windshield and gasket in place.)
I don't see a problem if you mount it like it was done originally...
Old 05-11-2017, 09:55 PM
My 33 mounts on the inside of the reveal. I had the glass man urethane it in.
Have them run a bead of urethane around the outside so it looks close to original. The garnish covers the inside so it looks original.
Old 05-13-2017, 04:31 PM
I totally forgot that you have basically the same car as I do, OldIron.
Did you need to get any rubber molding around the glass before urethaning it in?
Old 05-13-2017, 04:48 PM
No just urethane it in
