My Dodge Bros coupe!
Had these fishplates made for the front of my frame. I always think about what fool welded this frame up! [ddd:eek::eek:[ddd
You guys should sell those! Look cool!!!!!
Thanks... I was thinking about making some car club style plaques too. Told my friend I had some fishplates made & he asked what a fishplate was & I told him... "fishplates are what you use when you don't trust your own welding"! :D
Made the bottom coilover brackets out of some 2"x4" 3/8" & got um tacked in today. Hot as Tejas blue blazes in my shop all day so will finish welding them in tomorrow morn! Can't wait to get to the front end.... me wants a roller!!! :D
I bought the front end of a '46 Ford from my buddy & so far am using the spindles, tie rod, drag link and bones. I'm using the front bones for the rear & had these brackets made & welded them up today. The weld in bungs from Speedway will be here tomorrow & I'll finish them up.
I really like the rear end you're using!!!!!!!!!!!!!!!
Me too, I ripped the quick change outta my truck before I sold it to use on this build! :D
If memory serve... Once the spring was mounted in front of the axle (1935) the factory put the bend in the bones.
And yet another Dodge!!!!!!
Yep... I scored a really cheap body! [ddd
Are the bones on a 46 bent that way from the factory?
Or are all of them that way?
Yeah they were bent from the factory & fit perfectly on my application because of it!
I think that's right... it was to clear the tie rods... sorta like hairpins but only half a pin! :eek:
