Go Back   Undead Sleds / Rat Rods Rule - Hot Rods, Rat Rods, Sleepers, Beaters & Bikes... since 2007! > Need help identifying an item! What the heck is it?!?
Need help identifying an item! What the heck is it?!? Need help identifying a part, car or what ever... post it here!!!
Old 02-07-2017, 09:20 PM
"Detroit Steel" but may not be cost effective
Old 02-07-2017, 11:25 PM
Check out wheels for UPS trucks
You might google
6 lug budd WHEEL 19.5 x 6.00 motorhome truck DUAL rims dodge ford
Old 02-08-2017, 09:19 PM
offroadrolls's Avatar
offroadrolls offroadrolls is online now
All great input and suggestions, thanks to all! I went the bus route because I have a friend that wrenches for the city so I figured he might have a line on some used ones. He in turn gave me the number of a guy he uses out in Grand Junction for the big truck parts. I called him and he's going to look to see what he might have and get back to me.....got my figures crossed. Then I'll have to put rubber on them. $$$$$$$
Hot things look just like Cold things
Offroadrolls build:
http://ratrodsrule.com/forum/showthread.php?t=23696
42 Chevy PU build:
http://ratrodsrule.com/forum/showthr...ht=42+chevy+pu
Old 02-09-2017, 02:30 PM
ssimpala ssimpala is offline
I've got a water trailer made out of an old bobtail truck chassis that had widow makers on it. My local farm store had a set of new wheels to fit it for about $50 each.
Old 02-09-2017, 07:40 PM
6 on 8.75? Tubeless or split ring?
Offroadrolls build:
42 Chevy PU build:
Old 02-09-2017, 08:11 PM
Regular tubeless wheels. Check with one of your local farm coop stores...I guess you have them there? Do you have a cotton gin nearby? They always have lots of farm implement wheels.
Old 02-11-2017, 12:00 PM
Murdoch's is all we have and they just have trailer wheels in 15" and 16" five or 6 lug. The guy in Grand Junction says they don't make 6 lug 22.5's anymore but, he has 2 in old stock at 180 each. He'll keep an eye out for some used ones. The commercial truck rims like on the NPR Izuzus and such are 19.5 but rubber for those only goes up to about 33" diameter. 8.25 20's like are on my truck are about 37 inch so I need at least that. I found a good source for 9 x 20 split "rings" @ 40.00 each but those would be for tube type tires only. But, I found out they do make a 9 R20 Radial tire for those rims. So, I could go with 9 20 split ring wheels, radial tubes and 9 R20 radial tires and life would be good until I got a flat and couldn't just put a plug in it. Last, the tires on it now hold air and it rolls, I have a ton of stuff to do on the truck before I actually "need" tires.So I'm just going to keep looking for the holy grail 6 lug 22.5 one piece tubeless rim on old school buses and class A motor homes from the 80's and 90's
Offroadrolls build:
42 Chevy PU build:
