Go Back   Undead Sleds / Rat Rods Rule - Hot Rods, Rat Rods, Sleepers, Beaters & Bikes... since 2007! > Engine Q&A!
Engine Q&A! The spot for engine talk, Q&A & tall tales!
Old 01-28-2020, 09:33 AM
26Troadster's Avatar
26Troadster 26Troadster is offline
Default off topic ford truck
anybody here know anything about 93 ford f150 5.0 fuel injection? i'm lost on my grandson's truck and am about to pull my hair out.
Old 01-28-2020, 03:06 PM
What's the problem? Symptoms? Do you have a code reader?
Old 01-28-2020, 04:01 PM
flashing no code no check engine light. passenger side runs great but pull any plug wire on drivers side and it makes no difference. it's the 5.0 multi port injection. it was a gradual thing as it started with a slight miss and over a two to three week area it went down on the drivers side. i did have to replace one injector and it is on the side that is not working. i'm just short of pulling it and putting a chevy 305 700r4 in it but my grandson knows nothing about cars/trucks. uses the i don't know what i'm doing, i told him none of us did when we started. i really don't want to pull it but i can't seem to figure it out. it has new plugs, wires, cap, rotor and o2 sensor.
Old 01-28-2020, 08:23 PM
Bamamav's Avatar
Bamamav Bamamav is online now
Stick a intake and carb on it, change to a 85 Mustang GT distributor and run it.....
2019 Undead Sleds Calendars available here--
https://www.zazzle.com/2019_undead_s...18503957825055
Old 01-28-2020, 09:09 PM
redidbull's Avatar
redidbull redidbull is offline
Head over to here and ask for help. Decent bunch. I have a 89 and they have been great. I hope to do what Bamamav mentioned in the future though. Jim
https://www.f150forum.com
Old 01-29-2020, 07:25 AM
bobby i have thought about changing the intake. i'll have to try to find one. the only thing i worry about do that is the aod trans.
Old 01-29-2020, 08:51 AM
Bamamav's Avatar
It's not that hard, you can buy ready made brackets and cables or do like I did and modify stock stuff. The main thing is the carb linkage bracket--you want the TV cable to move exactly the same amount as the gas cable, but in the opposite direction. I used a stock cable, made a bracket to mount it to the intake, and then I fabbed up a bolt on arm for the carb that puts the TV cable the exact same distance from the carb throttle shaft as the throttle gas cable is in the opposite direction. If you look through my build pics I think there is a pic of the lever arm I made out of aluminum. Both cable connection points are exactly the same distance from the throttle shaft, so they move through the same arc. It's best to build a little adjustability into your cable bracket, a slot to move it works well, you want the TV cable to be snug at idle, but not tight, just no slack in it. Then if you have to adjust the shift points you can tighten the cable a bit or let off a smidge, better a little tight than too loose. Too loose will allow it to slip in gear, a no no, tight will just mean a quicker, firmer shift.
There is a factory carbed AOD combo, I can't remember what year it is right now off the top of my head, maybe 85? If you could find one of those you'd have the correct carb and TV cable brackets to do the swap with.
Old 01-29-2020, 01:18 PM
forgot to say when this started the wipers and radio sopped working as well.
Old 01-29-2020, 05:36 PM
Having no idea what you've done so far, and at the risk of stating the obvious...
- Do you have power to the non-functioning injectors? You should have full battery voltage at each.
- Your computer pulses the injectors via connection to ground. Poor grounds are the source of countless issues. I don't know where your computer's ground terminal is, but I would find it and any others. (I suspect the wiper/radio death is a ground problem as well.)
Assuming you have power to the injectors and proper grounds, you might have a harness issue. You can test the harness (from the computer connector pins) for each injector's ground with an ohm meter. I can find that information if you want it...
Old 01-29-2020, 08:38 PM
Bamamav's Avatar
I think Dr C is right, sounds like a ground issue. Make sure there is a ground strap from the engine to the battery as well as on to the body/firewall area.
