Go Back   Rat Rods Rule / Undead Sleds - Hot Rods, Rat Rods, Beaters & Bikes... since 2007! > Undead Sleds... makin' old tin Undead every day! > Rat Rod & Hot Rod Talk
Old 07-11-2018, 04:53 PM
tomtbone's Avatar
tomtbone tomtbone is offline
Default Hydro-Boost
So I'm running a 454 with a Big Cam therefore low vacuum.
Here is the deal, I might go with a non-power steering set up, but want to capture the vacuum for the brakes. Not sure how to set up the system bypassing the power steering component?
Any thoughts would be appreciated.
Thanks.
Old 07-11-2018, 08:58 PM
Cbucket Cbucket is offline
So I'm a little confused by your question.
Power steering set ups typically run off a hydraulic system and have nothing to do with vacuum.
I would solve the vacuum problem with a simple electric vacuum pump.
Old 07-11-2018, 09:06 PM
tomtbone's Avatar
Yes that's good advice, but I believe they are quite noisy?
Just thought maybe the hydro-boost could be rigged some how?
Old 07-11-2018, 09:07 PM
kenny c kenny c is offline
My dad had a 70s Chevy 1 ton with hydro boost for the brakes but no power steering. We later added power steering to it.
Tetanus Tornado 49 F6
Old 07-11-2018, 09:40 PM
tomtbone's Avatar
OK ask your dad how its done.
Old 07-11-2018, 09:54 PM
keep the p/s pump for hyroboost only, it does not require the steering gear to operate.
Old 07-11-2018, 10:02 PM
I've always liked the hydroboost systems.
They work good.
Old 07-12-2018, 12:21 AM
I put a Hydro-boost unit on my Chevelle's LS3.. went from very lame brakes to super brakes. They run off your power steering unit & I swear by them. I tried using a elec vacuum pump & it was noisy & didn't cut it... the HB solved all my problems!
Originally Posted by BlueNorther View Post
keep the p/s pump for hydroboost only, it does not require the steering gear to operate.
What he said!
Old 07-12-2018, 07:35 AM
Would love to but I,m not going near the cemetery in the near future. Beside I can't hear the answers to my questions when I go there. The dirt muffles his reply.
Old 07-12-2018, 07:40 AM
tomtbone's Avatar
Sorry brother, thanks for information on the hydro-boost.
It appears it will work even without the steering side of it.
