carb cleaner
klink
Feb 22, 2011
644
Brighton, Michigan
Aluminum wheel cleaner works really well on carbs. If a good cosmetic cleaning is what your after the wheel cleaner will make them look as good as new.
Pine sol
Read about pine sol and tried it on a 4 wheeler carb and it worked fantastic!!! Put it in a clean paint can and diluited it 50/50 with water and left it overnight.it blew my mind how clean it was. Very cheap and you could pour it down the drain when you were done !!! Give it a try
Plus your carb will have a fresh piney scent.....:D
