So here is the update on the Buell Chopper. I have some time between projects and thought the best way to pick up the shop is to put the Buell motor into the frame. Well it was a good idea.
The frame is an 84 sporty frame that was sent to Led Sled customs when my buddy owned it. They installed the hard tail rear for a 200mm rear tire. Now in the past they have done ecellent work. This frame, not so much. My buddy had to send it back because they put a 130mm rear on it. They fixed it free of charge but he could see the back bone was tweaked a little.
So fast forward to where I bought the frame off of him and now am assembling it. The rear head hit the frame when I tried to put the motor in. Took off the rocker boax and got the motor in but cant get the box back on. need 1/2" clearance. take out motor, slice top tube, jack up tube (was bowed down before and was the issue we knew about) weld it back up, clearance is good, put motor back in.
New problem: entire motor area is 1" too short to fit the motor in. Front head hits the front tube, mounts are 1" away from fitting, rear mount is at an angle due to front hitting. They must not have measured when they cut it apart to put the right rear on.
Soooo.... Now I get to cut the frame in half, stretch it 1", realign it, and put it back together. Should have just built my own frame like I did with my last Bike and then I would know it was right!
