Old Wing
Was screwing around with this again the other day. Put on a new carb gasket, screwed with the air box, worked on some tank mounts, mounted the taillights and turn signals (roughly, need to clean them up a bit) and some other small stuff. But ya know any progress is good progress right?? Nothing photo worthy but a step in the right direction.
Pulled this out yet again the last couple days. Finished up tank mounts, modified seat bracket by moving it back an inch and down a hair. Put springs on the seat and plates for them to sit on. Got tired of seeing the primer so blew a little black on the frame. Then took the tank off and started putting a skim coat of filler on the seams to get the grinding marks out. Sanded it down a little then put on a little more to fill some pin holes. Not thinking I like the seat position that much. Looks too high. It is comfortable though......
