Old 02-09-2020, 09:17 PM
Bamamav's Avatar
Bamamav Bamamav is offline
Originally Posted by joedoh View Post
5 ton? because that makes a difference here, I can get a reasonable tow for about 2.50 loaded + hook for just a car, but for a 10k forklift you have to have a big un.
I dunno what a roll back would cost for that, but my buddy usually charges me about $85 flat rate up to 100 miles from his shop.
I can haul 50,000 lbs on my flatbed, thatís what I was referring to. I average a little better than $1 a mile because Iím empty half the time. I go out loaded and deadhead back empty every day.
Old 02-09-2020, 09:40 PM
joedoh joedoh is offline
yeah thats what I was quoted, the last forklift was only 4 miles away and it was $100 for a 5 ton rollback.
funny thing, he was unloading and he was watching the deck intently, well the front of the truck came up chest high and WABAM hit the ground when the forklift came off.
he said "oh".
Old 02-12-2020, 05:53 PM
motor mounts! the 4.3 needs to move aft, last truck I did 9 inches and fought the distributor going back in. this truck I settled on 7.25".
used my cheater jig, holds the tubes 16.25" apart.
usually I modify the original trans mount but this time just popped one out of some rectangle tube and some plate. the sides will bolt to the tube, allowing removal.
control arms and steering are here, I need the weight of the motor to change them. cleaned the parts I wouldnt be able to reach with the motor back in and squirted some matte black.
pulled the oil cooler. new oil doesnt need one, much better oil than 2003, and these always have leaks. you have to take the filter spin on adapter off first, remove the cooler, then put the filter spin on back on the block.
still snowy and wet out there, I should have the motor dropped back in maybe tonight and start on CNC cutting the mounts maybe tomorrow.
Old 02-12-2020, 11:46 PM
Torchie's Avatar
Torchie Torchie is offline
Good progress.
Old 02-13-2020, 02:00 AM
Burgerman's Avatar
Burgerman Burgerman is offline
Like the cheater jig and your simple trans mount. Any challenge up front changing your engine set back from 9" to 7.25"
Old 02-13-2020, 08:45 AM
05snopro440's Avatar
With most S10 frame swaps (even with a V8), you need to move the engine back around that much. No issues if it's rear sump.
My '46 GMC on Photobucket
Old 02-13-2020, 11:41 AM
I have done as little as 5 (needed a efan) and as much as 9.25. 7.25 will be right there, best fit I had was closer to 7 but on the last one I was still greedy enough to try more haha.
should have the motor in and be working on suspension later today
Old 02-18-2020, 09:44 AM
got motor plopped on mounts, lined up awesome.
was working on front suspension when travis called with another craigslist find, he is the guy who spotted that last stuff in the background. looked like a good mix of stuff, and a gmc hood in there that I knew he needed, did I want to go halfsies and pick up asap (hour and half drive one way)? ok I guess.
I seriously underestimated what people have again. looked manageable from the pics, but when I got there it was 3 hoods, 5 front fenders and a rear, 5 doors (needed more doors right?) 3 sets of running boards, inner fenders, bumpers, on and on.
had to leave the bed for a second trip, there was so much. good condition 39 international bed.
today I started on suspension again my neighbor called and said he could start the driveway project with his backhoe at the new property, so looks like another delay haha.
File Type: jpg 60332107906__B9F2D2D0-9CF4-42E5-9786-25D9130658EA.jpg (151.8 KB, 29 views)
File Type: jpg 86346495_924037584681930_1907872988833775616_o.jpg (159.7 KB, 31 views)
Old 02-18-2020, 12:30 PM
BillM's Avatar
BillM BillM is offline
Wow that sure likes like a score to me! Way to go JD.
Old Today, 02:10 AM
picked up the 39 bed, would have taken the chance just towing it but the distance said be smart.
rebuilt the front end of the donor, the upper bushings were really wasted but the balljoints were great.
it made me surprised the tie rods were bad, but I got them in the kit so I got them ready. the old ones wouldnt come loose from the center link, not enough swing for my bfh, but I got a new center link too so no big deal. it was then I realized the slop I thought was the tie rods was actually the idler arm. which didnt come in the kit. oh twell, a quick run and everything buttoned up.
time to mess with the cnc table. everything went good on the dry runs but when I gave power to the plasma it just stayed on for the whole travel. I dinked around with it, it was the first cuts after all maybe something in my inexperience... nope. i noticed the plasma would fire every time I plugged in the special cnc connector.... sure enough, i peeled back the shrink wrap and it was shorted.
after that, easy peasy.
you can see some of the tribulations haha. but everything worked out perfect. time was I would spend the day cutting and grinding the individual parts and trying to make them match. this was cut AND bent in 45 seconds. no finish work required.
tomorrow I will cut the rest. all that farting around trying to troubleshoot really showed me how fast I could prototype something with this. its really crazy how easy it is.
File Type: jpg 60409333920__1DE0C3E4-9A52-436C-A343-F376054EF3ED.jpg (139.2 KB, 1 views)
