Willys long cab
Progress.....
Slowly getting things done.
I got the grille put together today. The cross bars are in good shape except for the top one. I took it to Albuquerque to get it rechromed but after going to 3 different shops I decided it's good enough for a driver and brought it home for installation. $95.00 AND 6 WEEK!!!! :eek::eek: [S[S
IT AIN'T NO SHOW TRUCK.
I know you need it for the truck, but that would be a terrific piece of wall art.
You must be reading my mind Bob. I was thinking that same thing when I was installing the lights and checking their functionality.
I'm going to see if I can come up with one for a wall hanger.
Man that looks good! It's called 'vintage' chrome - if you had gotten it plated, it would have made the rest of the bars look bad...:cool:
You are right as rain there ZZ. I'm just going to polish it up a little and maybe rub a little wax on it and call it good.
Sounds weird but, a coke and a ball of aluminum foil rubbed over the top bar will cover most of the problems. Or just leave it because it looks fine to me.
Still after it.....
I got the radiator and overflow tank in place on the grille today. Makes a tidy package that's ready to put in place soon.
Then I decided I'd use the space behind the steering column for the fuse block.
That will make for easy access with a removable panel to hide it.
Installed the steering column and almost ready for the fun of wiring this thing. I'm one of those that enjoys the process. [S:eek:[S
