Body... Talk & Q&A Top Chop, Channel & General Body Q&A |
Thread Tools | Display Modes |
I remember zzrodder saying he scrapes paint off. I for one would like more information about that. It might be an answer for you too.
I've seen old enamel paint do that. Unless a hardener is added, enamel never gets fully dry, it's always a bit soft. You may have to use a chemical stripper and a razor blade to get the old enamel off. If you get one that is water soluble, you can neutralize it with soap and water after you are through. I stripped a hood that had about six layers of unknown paint on it in about an hour. Got it down to metal and the original primer, washed it, let it dry then sprayed a primer sealer over it. Three years after I painted it, it still looked good.
Dry strip it with a razor blade. Effective, won't harm the surface and no residue to come back and bite you in the ass later...
I'm the dirty dozen for the price of one... |
I cleaned the hood really good last night, hoping it was a tree sap clear coat but turns out it is brush paint, probably an oil base enamel. Its not gonna scrape off without a stripper. I've never seen paint this hard.
Blue Eyed Devil gave you the correct answer.
I use a flat wire wheel, works well to get down to base primer or sometimes all the way to metal.
If it's gumming up the paper, it's not hard. That's the issue.
Re read my post above /\/\/\
Your right, its not hard. I tried the scraping, its worked for me before on a few cars, but not this one. Its just the hood and fender so i guess I'll go ahead and make a mess with some stripper.
Bookmarks |
Thread Tools | |
Display Modes | |
