WHAT Transmission is this???
christcrusader13
Zip-Tie Mechanic
Aug 21, 2013
1,424
Loudon ,TN
Okay, I pulled a motor and transmission from a mid 80's pick-up, still need to verify the VIN....
It looks like a turbo 350 long shaft and also has the vacuum plug on the passenger side of the transmission body.
It also looks to have a plug to a 700R-4 transmission on the driver side
I have [S on this one and I'm not getting anywhere....
Truck had one of those wonderful electronic quad-ra-jets....
Any ideas? :)
in picture #2 there is a domed looking cover. there should be a spring wire that goes in the hole above the cover and in a hole on the bottom side then slips over the cover to snap in the hole in center of the cover to keep it from coming off. i had one come off at a stop sign because it didn't have the lock wire and dumped all the fluid on the spot.
Thanks, I'll have to hunt for one of those.. A transmission losing it's blood = death LOL
They did not use the wire clip on the 350C trans.....
But you better pull the governor to check for a stripped gear and stuck valve.
that's funny, i have had 3 th350c's that did have the locks. it was one of them that left me on the side of the road.
