How To Remove Seam Sealer???
christcrusader13
Zip-Tie Mechanic
Aug 21, 2013
1,424
Loudon ,TN
I am preparing to join the two haves of my Chevy's together.. and there is a good bit of what looks to be factory seam sealer on the Caprice there the floors were fastened to the rockers...
Any idea how I can remove that so I cam weld some clean metal to the new metal I have to connect the 50 Chevy and the Caprice Chassis?[S
I know it melts with a cut off wheel...LOL :D
My Son Dan had a ton of seam sealer and floor tar to remove from the interior of the Mustang he is building. I gave him my Harbor Freight air chisel and it made short work of it. The thing vibrates and all you have to do is hold it against the work and keep pressure on it, the tool does all the work and gets it off cleanly.
Heat gun and a putty knife.
Then I go after that with a wire wheel on a drill.
Torchie.
thanks guys....
Heat gun - Check
Putty Knife - Check
Air Chisel - Check
Looks like I got all that I need! :D
