Go Back   Rat Rods Rule / Undead Sleds - Hot Rods, Rat Rods, Beaters & Bikes... since 2007! > LS motors!
LS motors! LS talk & Q&A!
Old 03-03-2017, 10:17 AM
Flipper_1938's Avatar
Flipper_1938 Flipper_1938 is offline
He recycles the right way
Default Which oil pan?
Seriously thinking about pulling the 5.3 out of my stalled fargo project and sticking it in the studebaker. What is currently "the" cheap oil pan to buy for better clearance?
There are two things in life where penetration is really important .....and one of them is welding.
My 48 chevy flatbed http://ratrodsrule.com/forum/showthread.php?t=604
The Roofus Special http://ratrodsrule.com/forum/showthr...ghlight=roofus
Old 03-03-2017, 10:30 AM
The pans on the truck engines is like the SBC with the sump in the rear.
Old 03-03-2017, 10:36 AM
....but it hangs way down. With the studebaker hood being so low, the motor is going to have to sit low in the chassis. I think I will need more ground clearance.
Old 03-03-2017, 11:52 AM
GM Muscle car pan is $200. Holley 302-1 looks like it has more clearance but it is $389. Any other options?
Old 03-03-2017, 12:43 PM
Gm musclecar pan is only 3/4" shallower than a normal truck pan?
Old 03-06-2017, 06:05 PM
looks like you need a F-body pan (Camaro-Fbird)
see here:
http://ls1tech.com/forums/conversion...-oil-pans.html
Old 03-06-2017, 09:41 PM
see here:
I don't know that the camaro pan will clear the jag rear rack and pinion.
Old 03-07-2017, 10:04 AM
I guess I will try and mock it up this weekend as is and see how bad the truck pan sucks.
Old 03-08-2017, 04:48 PM
jfg455's Avatar
jfg455 jfg455 is offline
The Hot Rod Cop
Later model truck pans are an inch shorter than the early ones. You would need an 08 + truck pan. F body is the shallowest on the rear sump but the sump is long front to back. The holley pan is slightly longer height wise and shorter lengthwise. CTS-V is thinner at the front then an F body but is slightly deeper at the back. Could just get an 01-07 truck pan and cut it to fit. That has been done as well.
"Try this link S10 on RRR " Sam Fear
"people riding so many scooters on the country mountain roads it looks like Thailand." Yodaforce
"all the ones I find around here are as solid as tin foil....." Neverdone
Giffins Performance custom CNC plasma cutting, home of the LSX swaps!
Turbo Datsun Build
52 COE Ramp Truck Build
1950 GMC Build
Old 03-08-2017, 07:09 PM
Bamamav's Avatar
Bamamav Bamamav is offline
But why is the Fargo stalled?
