spark plug gap ...
23crate
Moderator
Staff member
Moderator
Sep 26, 2014
1,381
new zealand
Toyotas..
apparently the plug gap is supposed to around 17 thou... I can attest to the fact that the dam thing still runs with a gap of 55 thou +
recently ive noticed abit of top end rattle at low revs ... after a some thought may brain said check the plugs .. the corolla has done nearly 260000km ~having never checked the plugs since 126000km when I bought it...
in my youth a hacksaw blade measured 25thou, good for most plugs and you knew pretty quick if the gap was a little big or too small ,, reckon that's more than 2 blades!!
got to laugh a bit ...
Yeah, that looks to be a little much! :D With today's electronic ignition, you can get away with it longer than when we had points. Back then, .035 was normal, now .055 is normal for some engines.
I think you got your moneys worth out of those for sure![cl
DR C .. broke out the wire wheel gave those plugs a bit of a tickle up ~ reset the gap and chucked em back in ..
as we say down under " She'll be right " seemed to run ok ..
Bama.. they good for a few thousand more,, after cleaning them up they looked like new !
then I pulled that dam beeper out that lets you know when your going backwards or the door is open .. reckon I can work those things out myself...:D
