Stuck hose
Croozer
Active member
Sep 21, 2007
33
Upstate NY
If you ever painted your car and tried to drag the hose around the tires you know it always gets hung up. The cure is take old brake shoes and place them in front of the tires where the hose would hang up...Problem solved.
We use shoes off of big trucks. They stand 6" off the ground instead of 2". Work alot better and most truck service places will give you several unless they are sending cores to be relined.
