Old 03-20-2017, 05:48 PM
DozerII's Avatar
DozerII DozerII is offline
Really nice Willy
Glen
My 29 Essex Build http://ratrodsrule.com/forum/showthread.php?t=34026
Don't give up, it's far too much fun once you can drive it.
Old 03-21-2017, 06:47 PM
Skip's Avatar
Skip Skip is offline
Love the combination switch idea. I too have considered it.
39 Ford PU Build. http://ratrodsrule.com/forum/showthread.php?t=36459
The thing about a '39 Ford pick-up is that that ugly grille kinda' grows on ya' after a while.
Not taking anything too seriously.
Old 06-23-2017, 12:02 PM
willyD's Avatar
willyD willyD is offline
I did a bit more work to the Willys in the past few weeks. I bought one of these cast finned coil covers to check out. They are reasonably cool. I refinished it and built a bracket to mount it to my manifold. Before I did that, I changed out the heads, intake and put some vintage Cal Custom valve covers on it.
My 51 Willys Pickup build http://ratrodsrule.com/forum/showthread.php?t=31867
My 36 Ford Bobber build: http://ratrodsrule.com/forum/showthread.php?t=34104
Old 06-23-2017, 02:18 PM
soltz's Avatar
soltz soltz is offline
The Rat Captain
Thumbs up
Nice looking engine and yes the coil cover is kool where did you find it
Be Safe
and
Be Creative
Old 06-23-2017, 03:01 PM
willyD's Avatar
I found it on ebay but Vintage Parts USA makes them. The castings are OK but they are a bit rough. They come somewhat polished. I bead basted this one and then tumbled it for a few hours to satin it out. That helps make the rough casting int he grooves between the fins less noticeable. I stuck some thin strips of weather stripping inside the cover to hole the coil in since it was a bit of a loose fit.
Old 04-13-2018, 03:09 PM
willyD's Avatar
I have been working on a new tach for my Willys for awhile now. I forgot to take pics of the rebuild unfortunately. It's a vintage Sun tach. I pulled the original 3500 rpm guts out and replaced them with modern electronics. The main drive board is actually in a separate pod that I will mount under the dash. I had to get a new face made for it which I think turned out really well. The needle doesn't line up perfectly but it will be good enough. The cup on the back is the top of an old Pyrene fire extinguisher.
Old 04-13-2018, 03:17 PM
Very unique tach, willyD. It's touches like that that make a car more interesting to look at.
Old 04-13-2018, 05:38 PM
smallfoot's Avatar
smallfoot smallfoot is offline
Beautiful job on the tach...like the way some of the simplest items of yesterday had so much more design built into the product...keep it up Willy!
Old 04-14-2018, 06:32 AM
DozerII's Avatar
That tach is really cool, like how you made it work.
Glen
