Go Back   Rat Rods Rule / Undead Sleds - Hot Rods, Rat Rods, Beaters & Bikes... since 2007! > Electrical... Talk & Q&A!
Electrical... Talk & Q&A! Electrical Q&A.. The shocking truth, tips, tricks & more!
Old 08-21-2018, 07:21 PM
fuzz's Avatar
fuzz fuzz is offline
Default wiring tachometers
What I have is a SBC in my rat with an HEI distributor. I installed a digital tach in the dash and wired it to the tach connection on the distributor.. First fired the engine and the tach reads crazy, little switch on the back set to 8 cylinders. I changed positions of the switch to see if there was any change. No change so I wired another tach to the same wire. New tach doesn't read correctly either. You can see in the pictures the digital tach reads about 1300 rpm at idle and the new tach reads about 600 which I believe is correct. But as I rev the motor both tachs seem to read incorrectly. My question is do you think wiring both tachs together could cause incorrect readings? The digital tach is defective, could it be causing the other tach to read incorrectly.
http://www.facebook.com/home.php?#!/...17143154968401
The funniest thing about my signature is that by the time you realize it doesn't say anything it's too late to stop reading it!!...
God bless our troops, especially the snipers
Always be sincere, even if you don't mean it.
Old 08-21-2018, 10:12 PM
Unplug the digital and try it
Old 08-22-2018, 07:03 PM
I'd do that to eliminate any interference or discrepancies between the two devices.
Just curious... what HEI do you have? GM, name brand aftermarket or E-Bay special?
