Rat Rods Rule - Rat Rods, Hot Rods, Bikes, Photos, Builds, Tech, Talk & Advice  since 2007!
Go Back   Rat Rods Rule - Rat Rods, Hot Rods, Bikes, Photos, Builds, Tech, Talk & Advice since 2007! > OHV 4 & 6 bangers!
OHV 4 & 6 bangers! 6 cylinder talk & Q&A!
Old 02-28-2017, 01:20 PM
old28's Avatar
old28 old28 is offline
Default 292 L6 LP Pistons
Anyone out there got a set of new or good used 292 LP pistons they would part with?
As Federal Mogul Seal Power has not made them for awhile, are there any parts houses (tractor or truck) that may be able to supply them?
Old 03-03-2017, 12:37 AM
high compression LP Gas???:
look at these:
http://www.ebay.com/itm/292-Chevy-Fl...-/322408929463
Old 03-03-2017, 12:40 AM
or these?:
http://www.ebay.com/itm/1963-1989-Ch...3D322408929463
Old 03-08-2017, 04:19 PM
gasser's Avatar
gasser gasser is offline
Default pistons
2 years ago summit racing still carried them I bought a set of .060 over for a 292 that still need to be built
Scrub Line: The point where the roof of the car hits the garage door opening
Old 04-29-2017, 04:22 PM
old28's Avatar
BlueNorther -- Looking for a set of good used LP Gas pistons as they will get my CR at 10.25 with a little block milling. The flat top ones on the bay would make 11.5 CR with my block as it is, to much.
gasser -- just trying to see if there are any good used ones out there. Summitt can still get them, takes 5-7 weeks.
Old 04-29-2017, 09:03 PM
old28's Avatar
How far down in the cylinder are the piston tops at TDC?
What cc is the dish of a stock D shape dish?
What cc is the dish of a LPG piston?
Old 05-19-2017, 12:24 PM
26Troadster's Avatar
26Troadster 26Troadster is offline
too much compression on lp gas? if i only ran lp gas i would want the higher compression to make the power that a gas burner will make.
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
