1934 Auburn build....my way
hankthebigdog
Oct 5, 2011
992
Pensacola, OK
I started on the 1934 Auburn and thought I would attempt to do a build thread on her. It may take the rest of my days to finish her, but here goes.
This is the day I unloaded her from the trailer and sat the parts up in a mock up fashion. Someday ...........it will be together.
I gathered a 9 inch ford 31 spline rear end from a 66 ford truck I have on the place that I use around here as a donor car. I am looking into mounting the rear axle on a set of international leaf springs from the front of a 48 IH truck I found at a friends junk yard.[length is close I think]
I have been working on mounting the rear axle on shackles onto the frame so as to get a measure for the wheel base of this car. I have now found the specs to be wheelbase to be 119in. I looks like I will need longer springs on the rear to let it get low enough to look correct. Still ciphering on that.
Got the frame to a stage I can set the wheels on the ground[stands] to get a look at the wheel base and visualize the front axle assembly. I am going with a new speedway 4 in. drop tube axle with ford spindles and chevy disk brakes. All new front suspension from speedway ordered and on the way.
Parts arrived and I am looking through the set up on the” red head”. I am now in the process of attaching the fenders to the frame to get the exact location of the axle. I will be setting spring perches next after a little more grinding and cleaning of the frame.[12-4-14]
adding some more
12-20-14..Out of school for the Christmas break and I am on go for the front axle mount . I got the front springs mounted and the axle perches mounted on top of the springs to lower it some. Tried under and it was way too tall. After a long day in the shop, I have the axle welded in at 7 degrees with the motor sitting in it for weight. I have not decided how to steer it yet, but that will come.
12-23-14….ok, today I started on redoing and dropping the rear springs about 3 inches. This was a long day of head scratching and trial and error to get it to where it looks close. I may be taking some of the leafs out to soften it up, but that will be later.[
hope I aint boring you guys
12/26-27/14….today I worked most of the time on the assembly of the front hubs and such. I got it completed but it takes a long time when you are working alone. I pulled a couple of roller wheels to put it on the ground and make her a roller.
12/28/14….I got some help from my church brothers and we sat the body on the frame. She is officially in the shop and is starting to look like a project. I adjusted the body to go over the frame modifications that were made on it before I saved its life. I worked most of the afternoon on getting the door mechanisms loosened up and called it a day.
notice the rust out in the bottom of the passenger side doors. That is all I have to actually cut out and patch.
