Go Back   Undead Sleds / Rat Rods Rule - Hot Rods, Rat Rods, Sleepers, Beaters & Bikes... since 2007! > Welding/Metalworking... Talk & Q&A
Welding/Metalworking... Talk & Q&A Get your torch, braze, hammer, tig or mig on here!
Old 03-08-2008, 08:39 PM
gnoub gnoub is offline
Default 48 Desoto Doors - Making them fit
Hey there, I'm new to this place and have a question on hanging the doors on my '48 De Soto. He's a rust bucket for sure. The hinges were shot and the floor is a mess. Thought I should get the doors back on to see if stuff fits before working on the floors and rockers. So, I found some good hinges and re-hung both the doors. It looks to like the top of the passenger door window frame it bent inward about 1/4 inch and seems to make contact with the door frame. And, the bottom left side of the door does not close flush with the rear 1/4's, sticking out about a 1/4 inch at the point where the B pillar and rockers meet.
Since the hinges are not adjustable, how does one get the top of the window frame back into alignment? Heat and a hammer? Hydraulic tools?
As you can tell I'm a moron and need all the help I can get!
Thanks for any illumination you can provide.
Gary
48 DeSoto S11
www.wrenchhappy.com
Old 03-08-2008, 08:49 PM
This will be a good question for the guys who know. I used to know a body guy who adjusted doors with a 2X4. He would shut the door on a board placed in just the right spot and bring the fit around. I am sure there must be a better way, but I don't know it.
Welcome to the site.
Old 03-09-2008, 09:03 AM
Bonehead:
A friend of mine just gave me the same advice. Low tech is good. Kind of scary though that you can adjust your body with some 2 x 4's. Planning on trying this today. Not sure that it will make much difference on the lower door but we'll see.
Gary
48 DeSoto S11
www.wrenchhappy.com
Old 03-09-2008, 10:47 AM
4dr orphan's Avatar
4dr orphan 4dr orphan is offline
Gary,
The block of wood is a good way to make the adjustments IF your door skin is flush with the quarter. You've indicated this is not the case & that the door skin is "out" that same 1/4" as the window frame (appears to be ) in. This is an indication to me that either the bottom door hinge is "out" i.e. away from the cowl, OR the upper hinge is too far in (toward the cowl). Until you find some semblance of adjustment in the hinges, I'd stay away from the wood trick. It is imperative that you align the door skin flush (to the quarter) first & formost. The window frame is aligned after that.
JMO
I was born an adult in search of a childhood, and (at 62) have succeeded beyond my wildest expectations!
Remember....If you haven't grown up by age 50........you don't have to!
Old 03-09-2008, 12:39 PM
JMO:
The hinges don't seem to be adjustable on this car. At least I can't figure it out. Now the floors are mush and the rockers are basically non existent. So, maybe the base of the A pillar has moved??
Gary
48 DeSoto S11
www.wrenchhappy.com
Old 03-09-2008, 03:54 PM
4dr orphan's Avatar
A distinct posibility, but remember the cowl is still a major supporter of the door's weight. If the cowl is still bolted to the chassis and has retained its integrity/strength, my bet is hinge alignment.....
Copyright ©2000 - 2022, vBulletin Solutions, Inc.
