My 1926 Dodge build start
I didn't get a picture of the part I made, it is a piece of 5/8 thick plate, welded inside a piece of 2" pipe, I drilled all the way through the frame, that way I could get to the nut on the tierod end.
Here is the shocks setup. I am going to run a piece of teflon between the arm and the wishbone.
Got the tilt steering column mounted. It is from a 1994 chevy truck.
Got the tail lights mounted. Here's what She is looking like so far. Just about ready to tear her down to finish welding on the body and frame. See anything I should do different?
got everything fitted and back off again to do some final welding on the frame. I hope this will be the last time.
welding up the transmission tunnel, need to add some steel on the cowl. I think I have been welding for days now [;)
